I have a WiFly on Arduino Duemilanove, just getting started and trying to get it to connect to my network.
Going through the tutorial http://www.sparkfun.com/tutorials/158 I’ve loaded the WiFly Transparent Terminal Sketch and am just going through tera term and trying to manually get it online.
the wireless passphrase contains a space and the replace option doesn’t seem to be working properly
the manual (http://www.sparkfun.com/datasheets/Wire … SX-um2.pdf) says:
For example, if the ssid of the AP is “yellow brick road”
You would enter “yellow$brick$road”
Using the ‘get w” command will properly display the value:
SSID=yellow brick road.
So I try:
<2.21> set wlan passphrase yellow$brick$road
AOK
<2.21> get wlan
SSID=mySSID
Chan=0
ExtAnt=0
Join=1
Auth=WPA1
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=0
Passphrase=yellow$brick$road
It’s still showing the “$” character in the passphrase. I checked the “opt replace” value, and it seems to be correct (0x24 = $):
<2.21> get opt replace
JoinTmr=1000
Replace=0x24
DeviceId=WiFly-GSX
Password=
Format=0x0
Sensors=0x0
When I try to join it says AUTH-ERR
No, I cannot change the passphrase of my wireless network. It’s a corporate network and I’m not in control of it.
Any thoughts?
