I changed some setting in my wifly and I used to be able to telnet to it through port 2000 but not I can only telnet to it in port 80 and I get a blank screen and as soon as I type in any character it ends the terminal session.
How do I fix this?
I tried pulling GPIO pin high and turning it on and it creates an adhoc network and I can only telnet to it on port 80
Have you tried setting the port in cmd mode:
set ip localport 2000
save
reboot
You may have to use coolterm and teraterm if you cant get into cmd mode through telnet.
Hope this helps.
save
reboot
Hope this helps.
