we’re looking at using the WiFly shield: sku WRL-09954
does WiFly shield need an antenna? what part number?
what’s its range?
what radio frequency does it use?
what happens when I put it into an enclosure that shields the world from my gizmo’s RF noise?
chrisjp
2
jspoonmaker:
what’s its range?
You can use the “internal” antenna which is chip based, or you can add an additional antenna (can only use one at a time) on the provided connector.
Range is difficult to estimate, I use it indoors through 2-3 walls without problem.
Radio frequency is standard 2.4 ghz band.
Depends on the shield
If you shield 2.4 ghz it’s not going to work
