The serial monitor is not displaying any output for command Serial.println(“Any text”) when running in Windows 11 (24h2) and Arduino 2.3.3 Specifically on SIK_Circuit_5B_RemoteControlRobot. Please advise if there is a solution because this important project is not working for me.
Double check the baud rate in the IDE matches the code you’re running.
I certainly have checked the baud rate when opening the serial monitor.
…what’s it set to? Is newline enabled? Do the other examples print to the serial monitor?
