Can I use a XBee module to transmit image from a regular webcam to a nearby pc? Range should be app. 100m or larger
Thank you ![]()
Thank you ![]()
yes, if…
you know how to get the video digitized and compressed
you use 1CIF frame size (reduce data rate)
the 100Kbps or so net yield rate is good enough
so, it depends.
Generally, if you want motion video, then no, 802.15.4 is too slow.
