Wireless weather
I’m going to be building a weather station using the proton weather shield. I would like to have 2 wireless displays (probably 4d touchscreens). Would I use 3 xbees for this, or would Bluetooth be a better idea?
From my experience, the xbees will be more straightforward to use. I assume you’re transferring only weather data and you’re driving the displays using a separate controller?
Yes, that’s what I was thinking with the 4D displays as they would be able to just accept the serial data sent from the xbees and the 4D’s do all the fancy stuff.
Raen:
bluetooth range is small.
XBee PRO S1 - good range but screens need 3.3V serial input
