Write "Program" to WT32
I’ve created a circuit which includes a WT32 and an FM transmitter based off of a BH1417F. I’ve managed to connect to the WT32 through serial and BGTerm and set it to run in A2DP and received audio from my Blackberry and send it to an FM radio nearby. I was wondering if I will have to plug this device into the serial port everytime to set these settings? I’ve designed the board with several buttons in hopes I can switch modes externally. Is this at all possible or am I overlooking something?
I’ve a solution to this WTxx issue that could be of use . If you are still interested reply here and I will detail .
spectable csherrit,
I don’t know if you still are in order to explain the issue regarding the software program for the WTxx (WT32) to manage audio in protocol A2DP,
I’d very interested of your knowledge and I’d be very glad if you should give me aby indications to do this.
Anticipately many thanks,
gioffix
(I apologize for my BAD ENGLISH … !)
