Wrong Dimensions
My board keeps coming out at the wrong dimensions because the little + sign used to move objects is outside my board. I use Eagle and nothing shows up in Eagle but when I process the files and view in Viewmate I can see the little + signs. How can I get rid of these?
When you are generating your Gerber files using one of the CAM files, make sure the tOrigins and bOrigins layers are NOT checked.
Hope this helps,
gm
Thanks, I got it fixed. I tried a few things, not sure what worked but I’m pretty sure just clicking delete in the areas where the little + signs were worked.
let’s hope you didn’t delete components you needed…
