Edit: Nevermind, I was able to successfully do it using Processing
I’m trying to configure two Series 1 Xbees using the Explorer Dongle. I’m on OSX, and trying to use Coolterm to adjust the settings. Whenever I type +++ I get an ‘OK’, but that seems to be the only command that goes through. Any idea what the problem may be? My only thought is that I have yet to solder the RTS to the DIO3 pin on the Dongle, but it doesn’t make sense given that the +++ command is going through.
I’m following this tutorial here: http://itp.nyu.edu/physcomp/Tutorials/XbeeBasics
