Xbee Explorer USB-C not showing up in device managment
Hey,
I have used the WRL-11812 explorer and now wanted to test out the WRL-22043, but when plugged in to the computer it wont show up in device managment.. any ideas what can be wrong?
Try a different USB cable, specially one you know for sure does data and power.
Thanks!! tried 3 different cabels but did not check if it was power aswell..
its now up and running!
Mark or label those cables!
The oval USB-C is the elegant conclusion to countless obsolete connector ancestors before it but could use some minor improvements to better indicate less-than-full function like OP encountered.
