XBee library for Flash / Flex (actionscript)
Hello. Does anyone knows if there is a library for actionscript to develop apps to communicate with Xbee module? My idea is to communicate with several wireless devices.
Thank you
As far as I know, serial port access is not directly supported by Flash/Actionscript. There is a third-party commercial library, MDM Zinc, that does provide that capability.
alexandre_fs:
Thank you
XBee can be simply a transparent serial port wireless extension. From A to B and back. Where A and B are user changeable on the fly, network addressed XBee modules. Just like a LAN with MAC addresses for source and destination NICs.
So, what I could do is simply create a socket connection in flash. Then with an application like SerProxy http://freshmeat.net/projects/serproxy/ I would transmit/receive data.
I will try that… thanks!
Good idea. Your serial proxy just might work. I’ll have to give it a try later today.
