xBee Problem
Hello there, I have to use the xBee system for a school project, but it isn’t working.
We want it to send the outcome of some sensors to a computer.
What we have:
xBee(http://www.sparkfun.com/products/10419) wired to an arduino Mega 2560, got the data in/out to the rx/tx and ground to ground and 3,3v to the 3,3v. Then we have an xBee on an xBee breakout usb board with an usb-cable to the pc.
One xbee is set to cordinator and the other one to end-device and both with the same network id.
But when I send something through the rx/tx it just doesn’t send it to the other xbee.
Is there anyone with a possible solution?
Thank you
The Xbee data-in should be connected to atmega TXD, and Xbee data-out to atmega RXD. When you speak, I listen. ( and vice-versa) :wink:
