I have an XBee Pro 900 Hp that needs to be able to read and transmit CAN data from a sensor. Are there any off the shelf products that you sell that could work, taking the CAN data and sending it from one XBee pro to another?
Absolutely! We carry this CAN-Bus Shield that can easily output its data to an xbee…it does require an MCU to parse its data before passing it to the xbee(s), check out the hookup guide
Thank you! What type of Arduino is this board designed for?
Uno R3 or compatible. It may also work on other boards but YMMV.
