ZED-F9R Pi-Hat question on how long the battery charge last
Battery: I read that the battery on the board needs to charge for at least 24 hours to be reliable for the board to hold memory. How long does this charge last for?
With regular-ish use it’ll last a few years…it’s a good idea to fully recharge it once a year (as described above, ~24 hours)
Thanks for the reply.
Before posting this for some reason I couldn’t find anything about this board. Then after doing a few more searches, I found some post. One, I think you commented on, said that the battery can deplete if the unit is storing info. It sounds like the more info stored in memory, the more drain on the battery. It would be nice to be able to ship my unit to my friend to test it out, without it losing its config.
If you have some time, can you please check out my other two post to see if you have any input, that would be greatly appreciated.
