I need some help. I am desigining a double sided PCB for the first time. I have one doubt that can I connect a track(in top layer) to a pad in top layer? Are the top and bottom pads connected ? Because the top pads are not soldered how it will be connected to component pin (say an IC Pin).
Thanks in advance.
Greetings (no name supplied)
First you didn’t say the pads are for through hole. I assume they are, because other wise you wouldn’t need to connect them.
If you are having the board made through BatchPCB the top and bottom pads will be connected with a through hole plating.
