Is there any 3d enclosure design available for AS7265x? If not, can you please point me in the right direction.
Not for that one ![]()
You can sue the Eagle files https://cdn.sparkfun.com/assets/8/6/1/4 … S7265x.zip (free program) and export a STEP/STL, then build an enclosure in Fusion360 or similar
I have tried to connect 1 mm tubes to the three sensors, but unfortunately the sensor does not work, it is fond in an I2C scanner but all values are solely zeros. I use it with an seeeduino XIAO.
