6" JST<->JST 2 Wire Jumper
It would be nice if you carried a 6" or so, JST to JST jumper. This would help connect things like the LiPoly Charger board to the Fio V3 so that you can run both boards.
An example usage would be:
LiPoly Battery → LiPoly Charger -(JST Jumper)-> Fio V3
I know you have the JST jumper that has the connector on one end, but I’m talking about one with connectors on both ends, that way we can disconnect either end without having to solder bare wires into the boards.
