6dof v4 bluetooth disabled/re-enable
I may have accidentally disabled bluetooth mode on the board while tinkering around with it. I was trying to setup auto run mode but accidentally switched off bluetooth mode. It may have switched to TTL mode. Now i can’t see the device anymore when I try to discover devices. Is there a way to switch it back to bluetooth mode without having to hardwire the board over serial.
