Has anyone had success using the A111 python examples?
Hi IST_Matt,
We certainly have tested the [Example Code for this board and they all work just fine. A couple of common errors are using a Pi 2 or older as the code is only supported on Pi 3 and newer. Another common issue is running an older version of Raspbian or other OS so make sure your OS is completely up to date. The other common issue we have seen is SPI not being enabled on your Pi.
If you are using a supported Pi with the most recent version of Raspbian and are still having issues, can you please describe the issue you are having in detail including any error outputs or screenshots of your error?](GitHub - sparkfun/SparkFun_Pulsed_Radar_A111_Example_Code)
