I am testing with the Exploration Tool, but the sensor values update only about once every 6 seconds, as shown in the video. Could you please help me resolve this issue?
The video is set to private
I am switching it to public.
Not entirely sure, but it looks like at least it isn’t skipping them…the frame counter at the bottom indicates they’re coming as batches. Do other examples have the same delay? You can try adjusting the settings on the right to decrease the minimum frame #, increase Hz, etc
Also be sure to close any other programs/stuff that uses serial ports, or maybe see if the problem is device-specific (try another PC?)
Thank you for your response.
I tried several other example sources, but the same issue persisted. Adjusting the minimum frame rate also did not result in any changes.
Additionally, I tested it on another PC, but the same issue occurred.
Do you see the same in the other version (python vs regular)?
