ACS723 Output - AC or DC Voltage?
I am planning to use this sensor to measure an 0-5A AC. Does this output an AC voltage? Or does it output a DC RMS voltage?
Hi bancelantoto,
The ACS723 outputs an analog voltage produced by an internal Hall effect sensor next to a copper strip. [This section of our Hookup Guide for both versions of this board will go into that in more detail. I would recommend reading through that section as well as the rest of the guide for a hardware overview of our two breakouts as well as an example circuit using an Arduino.](https://learn.sparkfun.com/tutorials/current-sensor-breakout-acs723-hookup-guide#the-hall-effect-and-current-sensors)
