hi, i need to add a switch to logging scales to shift logging intervals…help
//This is a bisic working version
//still have to connect red wire to 5vt
//problem LCD dimming
//error led is working only staying on if fail, no flash-great
// linked syn time and delay to log interval
//short flash with longer log intervall
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include “RTClib.h”
#include “HX711.h”
HX711 scale(3, 2);
#include <LiquidCrystal.h>
const int rs = 9, en = 8, d4 = A0, d5 = A1, d6 = A2, d7 = A3;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
// how many milliseconds between grabbing data and logging it. 1000 ms is once a second
#define LOG_INTERVAL 1000 // 10000 = 5 mins, 5000 = 1 min, 1000 = xx mills between entries (reduce to take more/faster data)
// how many milliseconds before writing the logged data permanently to disk
// set it to the LOG_INTERVAL to write each time (safest)
// set it to 10*LOG_INTERVAL to write all data every 10 datareads, you could lose up to
// the last 10 reads if power is lost but it uses less power and is much faster!
#define SYNC_INTERVAL LOG_INTERVAL //
uint32_t syncTime = 0; // time of last sync()
#define ECHO_TO_SERIAL 1 // echo data to serial port
#define WAIT_TO_START 0 // Wait for serial input in setup()
// the digital pins that connect to the LEDs
#define redLEDpin 6
#define greenLEDpin 7
RTC_PCF8523 rtc;//RTC_DS1307 RTC; // define the Real Time Clock object
char daysOfTheWeek[7][12] = {“Sunday”, “Monday”, “Tuesday”, “Wednesday”, “Thursday”, “Friday”, “Saturday”};
// for the data logging shield, we use digital pin 10 for the SD cs line
const int chipSelect = 10;
// the logging file
File logfile;
void error(char *str)
{ Serial.print("error: ");
Serial.println(str);
digitalWrite(redLEDpin, HIGH); // red LED indicates error
while(1); }
//HX711 scale(3, 2); // parameter “gain” is ommited; the default value 128 is used by the library
void setup(void)
{ Serial.begin(9600);
Serial.println();
pinMode(redLEDpin, OUTPUT); // use debugging LEDs
pinMode(greenLEDpin, OUTPUT);
{ lcd.begin(16, 2);// set up the LCD’s number of columns and rows:
lcd.print(“Zeroing Scales…”);// Print a message to the LCD.
Serial.print(“Initializing SD card…”);// initialize the SD card
pinMode(10, OUTPUT);
if (!SD.begin(chipSelect)) // see if the card is present and can be initialized:
error(“Card failed, or not present”);
Serial.println(“card initialized.”);
char filename = “LOGGER00.CSV”; // create a new file
for (uint8_t i = 0; i < 100; i++)
filename[6] = i/10 + ‘0’;
filename[7] = i%10 + ‘0’;
if (! SD.exists(filename))
{ logfile = SD.open(filename, FILE_WRITE); // only open a new file if it doesn’t exist
break; // leave the loop!
if (! logfile)
{ error(“couldnt create file”);
Serial.print("Logging to: "); // have to fix this
Serial.println(filename);// have to fix this
Wire.begin(); // connect to RTC
if (! rtc.begin())
{ Serial.println(“Couldn’t find RTC”);
while (1);
if (! rtc.initialized())
{ Serial.println(“RTC is NOT running!”);
rtc.adjust(DateTime(F(DATE), F(TIME)));// following line sets the RTC to the date & time this sketch was compiled
logfile.println(“Elapsed Mins,Date,Time (h
s),Day,Instant,Average”);
#if ECHO_TO_SERIAL
#endif //ECHO_TO_SERIAL
analogReference(EXTERNAL); // If you want to set the aref to something other than 5v
{ Serial.println(“HX711 Demo”);
Serial.println(“Before setting up the scale:”);
Serial.print(“read: \t\t”);
Serial.println(scale.read()); // print a raw reading from the ADC
Serial.print(“read average: \t\t”);
Serial.println(scale.read_average(20)); // print the average of 20 readings from the ADC
Serial.print(“get value: \t\t”);
Serial.println(scale.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight (not set yet)
Serial.print(“get units: \t\t”);
Serial.println(scale.get_units(5), 1); // print the average of 5 readings from the ADC minus tare weight (not set) divided
// by the SCALE parameter (not set yet)
scale.set_scale(2280.f); // this value is obtained by calibrating the scale with known weights; see the README for details
scale.tare(); // reset the scale to 0
Serial.println(“After setting up the scale:”);
Serial.println(scale.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight, set with tare()
Serial.println(scale.get_units(5), 1); // print the average of 5 readings from the ADC minus tare weight, divided
Serial.println(“”);// by the SCALE parameter set with set_scale
Serial.println(“OMG its about to start…”);
Serial.println(“”);
Serial.println(“Elapsed mins,Date,Time,Instant,Average”);
void loop(void)
{ lcd.begin(16, 2);
lcd.print(“Logging…”); // Print a message to the LCD.
lcd.setCursor(0,1); // Sets the cursor to col 1 and row 0
lcd.print("LoadCell: "); // Prints Sensor Val: to LCD
lcd.print(scale.get_units());
{ delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));// delay for the amount of time we want between readings
uint32_t m = millis(); // log milliseconds since starting
#if ECHO_TO_SERIAL
#endif}
DateTime now = rtc.now();
logfile.print(m/60000); // milliseconds since start
logfile.print(", ");
logfile.print(now.year(), DEC);
logfile.print(“/”);
logfile.print(now.month(), DEC);
logfile.print(“/”);
logfile.print(now.day(), DEC);
logfile.print(" ");
logfile.print(now.hour(), DEC);
logfile.print(“:”);
logfile.print(now.minute(), DEC);
logfile.print(“:”);
logfile.print(now.second(), DEC);
logfile.print(daysOfTheWeek[now.dayOfTheWeek()]);
logfile.print(", "); ///
logfile.print(“\t”);//
logfile.print(scale.get_units(), 2);//
logfile.print(scale.get_units(10), 2);//
#if ECHO_TO_SERIAL
Serial.print(m/60000); // milliseconds since start
Serial.print(" , ");
Serial.print(now.year(), DEC);
Serial.print(‘/’);
Serial.print(now.month(), DEC);
Serial.print(‘/’);
Serial.print(now.day(), DEC);
Serial.print(" (");
Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
Serial.print(") ");
Serial.print(now.hour(), DEC);
Serial.print(‘:’);
Serial.print(now.minute(), DEC);
Serial.print(‘:’);
Serial.print(now.second(), DEC);
Serial.print(“\t Instant:\t”);
Serial.print(scale.get_units(), 2);
Serial.print(" Average:\t");
Serial.print(scale.get_units(10), 2);
scale.power_down(); // put the ADC in sleep mode
delay(LOG_INTERVAL);
scale.power_up();
logfile.println();
#if ECHO_TO_SERIAL
Serial.println();
#endif // ECHO_TO_SERIAL
// Now we write data to disk! Don’t sync too often - requires 2048 bytes of I/O to SD card
// which uses a bunch of power and takes time
if ((millis() - syncTime) < SYNC_INTERVAL) return;
syncTime = millis();
{ digitalWrite(greenLEDpin, HIGH);// this was red led// blink LED to show we are syncing data to the card & updating FAT!
delay(500);// i just added this
digitalWrite(greenLEDpin, LOW);
} //turn off if combine leds was red led
delay(LOG_INTERVAL/1);// i just added this
logfile.flush();
} :mrgreen:
