adhesive used on keyboard trim
Does anyone know what adhesive is used to
hold the trim strips or decorative coverings
on a K811 keyboard?
It looks like some sort of very thin 2 sided tape or
film covered with rubber cement.
So, this is for a logitech K811 keyboard.
And it has strips of plastic that cover the screws.
The adhesive seems to be all over the area of the strips.
I wish you could get replacement strips! cheaply!
Google doesn’t know I thought you guys might.
Yes, it’s a very thin film with likely an acrylic adhesive.
You can this type of product for $6 from
https://www.findtape.com/3M-Scotch-5906 … 12/?tid=21
Thank you, very much!
My keyboard went haywire,
I tore it down, couldn’t fix it,
stopped using it, and set it aside,
decided to try it, and it works fine.
Go figure!? I hope it hasn’t become self-aware.
It probably has, and will fail at precisely those moments when you need it most.
