I have a discovery thermometer failed to display any characters on the screen, I found there’s a strange cable(it’s soft like a sponge) connecting to pc board and lcd which is no longer to be stuck to each other, wondering if we can use any glue to stick them back to normal ?
Thanks for response, I cleaned and put it back , nothing happened, the other side is LCD, I don’t have any ideas on how to solder it, any more other advice ?
This is a so called Zebra connector and is not soldered in place. It is help in pace by pressure and a tacky adhesive. Notice on the edges there is a black strip? If you look under a magnifier, you will see these are hundreds or thousands of unique conductors. Those conductors press against the PCB to form a connection. Zebra connectors are a royal pain in the neck. They are used for high volume production, but they have a high rate of failure from shock or vibration. Once disconnected they are essentially non repairable as the sticky edges are no longer adhesive. Purchasing a new connector may be possible if you can find the exact height, width, and length.
I think the zebra connector comes already primed with the sticky adhesive, although never having purchased one I can’t say for sure. I just know my success rate on getting those working again is ZERO.
