Most smaller LCDs have a single line of 14 to 16 holes along one side and to get these connected to a ribbon cable and so to an IDC connector is:
Slow work.
Complicated by often having to reverse pairs of the ribbon cable.
Tricky to reinforce the soldered joint to withstand stress - silicon sometimes ‘fumes’ and stuffs up the LCD.
The job looks amature.
How about a small ‘transition board’ that:
Takes a header strip 14 to 16 pins long - these plug into the LCD.
Has a patching area to swap connections around.
Has a 2X5 header socket for an IDC connector.
Maybe a LED to show power is on.
Regards Bill Legge
