Please can someone explain the differences between ADXL 335 and 337
Are they swappable?
I have a project built on 337s but 335s seem more available
thanks
Are they swappable?
thanks
It looks like the 337 just uses different MEM chip, with the same operating ranges and voltage - https://www.sparkfun.com/datasheets/Com … dxl335.pdf https://cdn.sparkfun.com/datasheets/Sen … DXL337.pdf
Appears the 337 is just smaller and draws less current ![]()
It should work just fine to swap 337’s in place of the 335’s (the chips likely have slightly different offset values, but that should not greatly impact the majority of use-cases)
