Hi everyone,
I’m using the STM32-P103 board with Eclipse and oocd 0.2.0.
my problem is that I can’t use debugging.
I use this for OpenOCD:
gdb_port 3333
Work-area size (RAM size) = 20kB for STM32F103RB device
set _WORKAREASIZE 0x5000
interface ft2232
ft2232_device_desc “Olimex OpenOCD JTAG TINY A”
ft2232_layout “olimex-jtag”
ft2232_vid_pid 0x15BA 0x0003
script for stm32
if { [info exists CHIPNAME] } {
set _CHIPNAME $CHIPNAME
} else {
set _CHIPNAME stm32
if { [info exists ENDIAN] } {
set _ENDIAN $ENDIAN
} else {
set _ENDIAN little
JTAG speed should be <= F_CPU/6. F_CPU after reset is 8MHz, so use F_JTAG = 1MHz
#jtag_khz 1000
jtag_speed 3
#jtag_device 4 0x1 0xf 0xe
jtag_nsrst_delay 100
jtag_ntrst_delay 100
#use combined on interfaces or targets that can’t set TRST/SRST separately
reset_config trst_and_srst
#jtag scan chain
if { [info exists CPUTAPID ] } {
set _CPUTAPID $CPUTAPID
} else {
See STM Document RM0008
Section 26.6.3
set _CPUTAPID 0x3ba00477
jtag newtap $_CHIPNAME cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_CPUTAPID
if { [info exists BSTAPID ] } {
set _BSTAPID $BSTAPID
} else {
Section 26.6.2
Low density devices, Rev A
set _BSTAPID1 0x06412041
Medium density devices, Rev A
set _BSTAPID2 0x06410041
Medium density devices, Rev B and Rev Z
set _BSTAPID3 0x16410041
High density devices, Rev A
set _BSTAPID4 0x06414041
Connectivity line devices, Rev A and Rev Z
set _BSTAPID5 0x06418041
jtag newtap $_CHIPNAME bs -irlen 5 -ircapture 0x1 -irmask 0x1 -expected-id $_BSTAPID1 -expected-id $_BSTAPID2 -expected-id $_BSTAPID3 -expected-id $_BSTAPID4 -expected-id $_BSTAPID5
set _TARGETNAME [format “%s.cpu” $_CHIPNAME]
target create $_TARGETNAME cortex_m3 -endian $_ENDIAN -chain-position $_TARGETNAME
$_TARGETNAME configure -work-area-virt 0 -work-area-phys 0x20000000 -work-area-size $_WORKAREASIZE -work-area-backup 0
flash bank stm32x 0 0 0 0 0
init
reset halt
For GDB:
target remote localhost:3333
break main
I got following Errors:
Open On-Chip Debugger 0.2.0 (2009-10-13-15:06) Release
$URL: http://svn.berlios.de/svnroot/repos/ope … /openocd.c $
For bug reports, read http://svn.berlios.de/svnroot/repos/openocd/trunk/BUGS
jtag_speed: 3
jtag_nsrst_delay: 100
jtag_ntrst_delay: 100
Info : device: 4
Info : deviceID: 364511236
Info : SerialNumber: FTS92Y5TA
Info : Description: Olimex OpenOCD JTAG TINY A
Info : JTAG tap: stm32.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG Tap/device matched
Info : JTAG tap: stm32.bs tap/device found: 0x16410041 (mfg: 0x020, part: 0x6410, ver: 0x1)
target state: halted
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x20000010
Info : accepting ‘gdb’ connection from 0
Warn : acknowledgment received, but no packet pending
Info : device id = 0x20036410
Info : flash size = 128kbytes
Error: AHBAP Cached values: dp_select 0x0, ap_csw 0xa2000012, ap_tar 0xffffffff
Error: SWJ-DP STICKY ERROR
Error: Read MEM_AP_CSW 0x23000052, MEM_AP_TAR 0x202d0dd4
Warn : Block read error address 0x202d0dd0, count 0x1
Error: AHBAP Cached values: dp_select 0x0, ap_csw 0xa2000010, ap_tar 0xffffffff
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f64f
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f650
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f653
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f654
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f657
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f658
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f65b
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f65c
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f65f
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f660
Error: Read MEM_AP_CSW 0x23000050, MEM_AP_TAR 0x5214f663
I tried a to reduce the JTAG speed but it didn’t worked out for me.. I Have no Idea what else I should do..
So any help would be much appreciated!
