flash programming ok, but debugging problem?
I am new to ARM, OpenOCD.
Can someone guide for programming flash of STM32F103ZC.
1.1 “My hardware” is just a minimum system built around STM32F103ZC.
Minimum system is nothing but Fig. 15 of App.Note AN2586
titled “STM32f10xxx hardware development: getting started”)
of ST Microelectronics,
1.2 I am using LM3S1968 Evaluation board as “JTAG debugger” for
“my hardware”.
I have connected “JTAG debugger” to PC using USB port and
“my hardware” using JTAG connector.
2.1 I have tried using Eclipse - GANYMADE as IDE. But it produces
following DUMP in the Eclipse…
(Note: it seems to detect both the devices viz. LM3s1968 &
STM32f103ZC)
Open On-Chip Debugger (2008-06-19 19:00) svn: 717
URL: http://svn.berlios.de/svnroot/repos/openocd/trunk
Info: options.c:50 configuration_output_handler(): jtag_speed: 40, 40
Info: options.c:50 configuration_output_handler(): Open On-Chip Debugger (2008-06-19 19:00) svn: 717
Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x3ba00477 (Manufacturer: 0x23b, Part: 0xba00, Version: 0x3)
Info: jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x06414041 (Manufacturer: 0x020, Part: 0x6414, Version: 0x0)
Error: jtag.c:1399 jtag_examine_chain(): number of discovered devices in JTAG chain (2) doesn’t match configuration (1)
Error: jtag.c:1400 jtag_examine_chain(): check the config file and ensure proper JTAG communication (connections, speed, …)
Error: jtag.c:1556 jtag_init_inner(): trying to validate configured JTAG chain anyway…
Error: jtag.c:1456 jtag_validate_chain(): Error validating JTAG scan chain, IR mismatch, scan returned 0x11
Error: jtag.c:1565 jtag_init_inner(): Could not validate JTAG chain, exit
3.1 How can i program the flash of STM32F103ZC of “my hardware” using
the LM3s1968 Eval. board as JTAG debugger?
Kindly provide Scripts & configuration file.
Hemant.
hemant.mscs:
STM32f103ZC)
Both TAPs belong to STM32. I suppose You are using wrong configuration file. Here is the correct one.
#jtag scan chain
#format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE)
jtag_device 4 0x1 0xf 0xe
jtag_device 5 0x1 0x1 0x1e
#target <type> <startup mode>
target cortex_m3 little reset_halt 0
run_and_halt_time 0 30
working_area 0 0x20000000 16384 nobackup
#flash bank str7x <base> <size> 0 0 <target#> <variant>
flash bank stm32x 0 0 0 0 0
P.S. Don’t forget about interface part of configuration file.
Thank you!!!
It seems that the device is being programmed properly.
I downloaded small program and the console showed the following message.
Info: options.c:50 configuration_output_handler(): jtag_speed: 10, 10
Info: target.c:237 target_init_handler(): executing reset script ‘program.script’
Info: stm32x.c:631 stm32x_probe(): device id = 0x10016414
Info: stm32x.c:670 stm32x_probe(): flash size = 256kbytes
Info: options.c:50 configuration_output_handler(): stm32x mass erase complete
Info: options.c:50 configuration_output_handler(): wrote 8492 byte from file ./main.bin in 0.953125s (8.700820 kb/s)
But when i tried to debug the program, it displayed the following…
No symbol “new” in current context.
target extended-remote localhost:3333
Breakpoint 1 at 0x8000110: file main.c, line 47.
localhost:3333: No connection could be made because the target machine actively refused it.
b main
monitor soft_reset_halt
“monitor” command not supported by this target.
monitor sleep 500
continue
The program is not being run.
clear main
Is somthing wrong with the settings in Eclipse?
Regards.
Hemant.
