adam.g
1
Hi folks,
I noticed a spacer is used for the RockBLOCK 9603 in the À La Carte design:
https://cdn.sparkfun.com/componentPhoto … /phplWEZ7W
Would it be possible to get a part number for the spacer? Currently measuring out dimensions for an enclosure.
Cheers,
Adam
Looks like the spacers are 13mm long, the file below is a mechanical drawling if that helps.
M2圆螺柱.pdf (183 KB)
adam.g
3
Thanks, Chris!
Helps a bunch. I always forget those RockBLOCKs have such small mounting holes.
Cheers,
Adam
