allow to move components a bit around
Would it be possible to allow moving components at bit around by hand? For example, if I put an IMU with a magnetometer, I want to move it to the edge of the board, to be away from where currents / RF modules / batteries will be located. Translation X and Y directions would be enough, i.e. only “stretching” wires in a sense.
this one is very possible. You need how to do it? or you just wanted tp know if it is possible?
