Hi…i’m getting crazy triyng to generate this Gerber files correctly from Altium…all the layers are Ok but the Top cooper layer and Top solder mask layer it shows little dots that i can’t find on the PCB file…if anyone knows how to correct this please share…I don’t know if this is a bug on the altium software or what…thanks in advance for the help…
What dots?
Go back to your PCB design and select Edit->Select->Outside Area. Draw a box around your board then press the delete key to remove any track fragments outside your board outline.
No try re-generating your gerber files.
Andy
Ah, those dots… I was looking at the board… lol
