neyric
1
Hi !
I’m using a WiTilt v2.5, which is a great product !
However, I often have to press the reset button between two connection, or after sending the “1” to start data reading.
Is there any way to get around this issue (send a reset from the software ?) ?
What exactly means the “status” LED ?
I’m looking for the solution… It would be very interesting to have a command instead of this reset…
KuRi
3
I am having the same problem…
If you connect / disconnect / connect you have to hard reset to continue working…
Is there any solution for this?
