Hi all
i’m quite new for this communication protocol
i’ve made a project that uses serial cable that consist of an ADC (TX out) → MAX232 → Commport
The adc and commport i set to 115200 bps … the result is OK
The 2nd project is i took out max232 and change it to Bluesmirf … it seems the data sometimes error and mostly crash (stopped)
My question is, Let say my ADC (its a PIC16F877) i set to 9600baud , the bluesmirf set to 19.2kbps and Commport set to 115,200 bps .
are these correct way ? i mean its not synchronize , but gives a time & eliminate bottleneck of data processing for each components .
I appreciate any comments (I need some info) … thank you …
