Hi !
I have an 9960 connected to Arduino UNO.
I have difficults to read both values at the same time.
Can you help me with an example that combine both sensors?
Thanks.
Hi !
Thanks.
Thanks for reaching out to us on this.
Please refer to the hookup guide for an example of each https://learn.sparkfun.com/tutorials/ap … 1615791300 , or this example with both https://github.com/sparkfun/APDS-9960_R … reTest.ino
Hope this helps, and happy sparking!
I used 3.3V pin of Arduino Uno and followed all other instructions. “APDS-9960” is not working, can you please let me know how to fix the issue?. I bought https://www.amazon.com/HiLetgo-APDS-996 … op?ie=UTF8.
You may have a bad board, contact Amazon to see if they can get you a replacement.
Also, the product you have is not a SparkFun product, you might try contacting the manufacturer “[HiLetgo” for more assistance.](http://www.hiletgo.com/)
hi, were you able to figure this out?. Ive been facing the same problem. Proximity and gesture separately work fine but when combining both, even just enabling the gesture with apds.enableGestureSensor(true) causes the proximity to lock at 20-30 values..doesn’t read anything in fact..
Are you using ours or the amazon they had?
