I want to put this out there to see if it is possible: I want an arduino to output analog, only to be read in by another arduino as analog. The reason I want to do this is because serial transfers for some reason lags the loop.
I’ve tried analogwrite output to analogread input, and all I got were either 0 or 1023.
As Mudo said, analogWrite sets up a pwm output. You need to add a low pass filter between the analog output and the analog input to be able to analogRead the analogWritten voltage.
