Hi
I am planning on using the following tutorial to build a system with a range of sensors, that sends the data to online storage.
https://learn.sparkfun.com/tutorials/in … -xbee-wifi
I need to use the following sensors:
Temp
Tilt (for a window)
Humidity
CO2
Nitrous Oxide
Sulphur Oxide
Air flow through a room.
Sparkfun sells sensor for Temp and Tilt.
Can anyone recommend sensors for the remainder which will be compatible with the project? Also, how difficult will it be to add to the code so that the system logs all of this data (I am new to arduino).
Thankyou
