I power-up the Arduino BT-V06, 3V3 Led was ON
The Bluetooth Dongle deteted it successfully (ARDUIONT) & shows the communication link
The ST Virtual Serial Port COM3 appearing in the Device Manager Hardware
I set ST Virtual Serial Port COM3 to 115200_8N1
I use the Arduino 0014 Editor, set Board: Arduino BT, set Serial Port: COM3
Copy Sketch: ASCII Table to Sketch: BT_V06_ASCII_Table, change to Serial.begin(115200); then Save!
Verify/Compile it with no error
Hit RESET button of the Arduino BT-V06
Upload to Arduino board, after awhile, the Arduino 0014 Editor showed:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
*) I tried several times in-vain, anyone knows why I could not upload? ![]()
