I just purchased an Uno R3 and would like to know what people think of this idea. (has anyone else done it?)
An arduino is much cheaper than a Xantrex battery monitor, so I decided to see if I could make a battery monitor.
Sensing voltage should be easy and I assume I’ll need to build a prescaling circuit or a divider for the 128v sense.
sensing current might be a bit trickier ? using a 1000a shunt either 50mv or 100mv
these will fill up some of the adc inputs.
The really tricky part I assume will be an amp-hour/kwhr counter, basically calculating amps drawn(?) and an avg voltage.
For a display I have a common 16pin lcd which should be very easy to hook up according to a tutorial.
I’m new to microcontrollers and dont have much coding experience so I will probably be on here often asking about this ![]()
any suggestions before I dive in?
