Can the 5V Arduino pro Mini provide power for the DS18B20 temperature probe and the 16X2 LCD display? I have the circuit running on the Uno and want to use it on the Mini instead. I see the RAW and VCC points but not a 5V output. Thanks!
If you have a 5V pro mini, then Vcc should be 5V output. There is no problem using that to power a DS18B20 and an LCD display with NO backlight.
Should be able to. Display takes ~125mA but the probe doesn’t say, although I just skimmed it.
Jremington beat me to it…
