armusbocd build for x64 anyone ?
hi ,
has anyone rebuilt openocd for use with ftdi x64 drivers ,
or could someone rebuild for me
thanks all
ftdi have drivers for x64, you can just use our
PID: 0x0004
VID: 0x15BA
to install the x64 drivers and there should be no problems
Tsvetan
thanks Tsvetan,
by the way the pid i believe should be 0x0003 ??
can anyone confirm this works or supply the inf & ini mods
i have try’d this , but either i have something wrong or openocd needs re compiling , so looking for confirmation
sorry:
ARM-USB-OCD PID = 3
ARM-USB-TINY PID = 4
Tsvetan
openocd appears not to accept an install path including \program files (x86)\ which is the default install under windows xp pro x64
i presume it checks the path and is being screwed by the (x86)
install into a seperate path works fine
