Has anyone successfully compiled the latest Artemis OLA from the GitHub.
Running Arduino IDE with what I believe are all the correct libraries, I get a stack of errors.
In file included from D:\Users\Steven\Documents\Arduino\Sketches\GPS_DataLogger\OpenLog_Artemis\OpenLog_Artemis.ino:278:
D:\Users\Steven\Documents\Arduino\libraries\SparkFun_Qwiic_Button_and_Qwiic_Switch_Library\src/SparkFun_Qwiic_Button.h:29: warning: "DEFAULT_ADDRESS" redefined
#define DEFAULT_ADDRESS 0x6F //default I2C address of the button
In file included from D:\Users\Steven\Documents\Arduino\Sketches\GPS_DataLogger\OpenLog_Artemis\OpenLog_Artemis.ino:273:
D:\Users\Steven\Documents\Arduino\libraries\SparkFun_MicroPressure_Library\src/SparkFun_MicroPressure.h:9: note: this is the location of the previous definition
#define DEFAULT_ADDRESS 0x18
D:\Users\Steven\Documents\Arduino\Sketches\GPS_DataLogger\OpenLog_Artemis\zmodem_sz.cpp:177: warning: "zperr" redefined
#define zperr(a, ... )
In file included from D:\Users\Steven\Documents\Arduino\Sketches\GPS_DataLogger\OpenLog_Artemis\zmodem_sz.cpp:66:
D:\Users\Steven\Documents\Arduino\Sketches\GPS_DataLogger\OpenLog_Artemis\zmodem_zm.h:49: note: this is the location of the previous definition
#define zperr(...)
In file included from D:\Users\Steven\Documents\Arduino\libraries\SparkFun_PHT_MS8607_Arduino_Library\src/SparkFun_PHT_MS8607_Arduino_Library.h:51,
from D:\Users\Steven\Documents\Arduino\Sketches\GPS_DataLogger\OpenLog_Artemis\settings.h:2,
from D:\Users\Steven\Documents\Arduino\Sketches\GPS_DataLogger\OpenLog_Artemis\OpenLog_Artemis.ino:130:
C:\Users\Steven\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.0\libraries\Wire\src/Wire.h:36:20: error: conflicting return type specified for 'virtual size_t arduino::MbedI2C::requestFrom(uint8_t, size_t, bool)'
virtual size_t requestFrom(uint8_t address, size_t len, bool stopBit);
In file included from C:\Users\Steven\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.0/cores/arduino/mbed-bridge/core-api/api/ArduinoAPI.h:30,
from C:\Users\Steven\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.0/cores/arduino/mbed-bridge/Arduino.h:17,
from C:\Users\Steven\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.0/cores/arduino/sdk/ArduinoSDK.h:9,
from <command-line>:
C:\Users\Steven\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.0/cores/arduino/mbed-bridge/core-api/api/HardwareI2C.h:39:21: note: overridden function is 'virtual uint8_t arduino::HardwareI2C::requestFrom(uint8_t, size_t, bool)'
virtual uint8_t requestFrom(uint8_t address, size_t len, bool stopBit) = 0;
C:\Users\Steven\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.0\libraries\Wire\src/Wire.h:37:20: error: conflicting return type specified for 'virtual size_t arduino::MbedI2C::requestFrom(uint8_t, size_t)'
virtual size_t requestFrom(uint8_t address, size_t len);
C:\Users\Steven\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.0/cores/arduino/mbed-bridge/core-api/api/HardwareI2C.h:40:21: note: overridden function is 'virtual uint8_t arduino::HardwareI2C::requestFrom(uint8_t, size_t)'
virtual uint8_t requestFrom(uint8_t address, size_t len) = 0;
Using library SparkFun_PHT_MS8607_Arduino_Library at version 1.0.3 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_PHT_MS8607_Arduino_Library
Using library Wire at version 2.0.0 in folder: C:\Users\Steven\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.0\libraries\Wire
Using library EEPROM at version 2.0.0 in folder: C:\Users\Steven\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.0\libraries\EEPROM
Using library SPI at version 2.0.0 in folder: C:\Users\Steven\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.0\libraries\SPI
Using library SdFat at version 2.1.2 in folder: D:\Users\Steven\Documents\Arduino\libraries\SdFat
Using library RTC at version 2.0.0 in folder: C:\Users\Steven\AppData\Local\Arduino15\packages\SparkFun\hardware\apollo3\2.1.0\libraries\RTC
Using library SparkFun_9DoF_IMU_Breakout_-_ICM_20948_-_Arduino_Library at version 1.2.9 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_9DoF_IMU_Breakout_-_ICM_20948_-_Arduino_Library
Using library SparkFun_I2C_Mux_Arduino_Library at version 1.0.3 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_I2C_Mux_Arduino_Library
Using library SparkFun_CCS811_Arduino_Library at version 2.0.1 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_CCS811_Arduino_Library
Using library SparkFun_VL53L1X_4m_Laser_Distance_Sensor at version 1.2.11 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_VL53L1X_4m_Laser_Distance_Sensor
Using library SparkFun_BME280 at version 2.0.9 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_BME280
Using library SparkFun_LPS25HB_Pressure_Sensor_Library at version 1.1.0 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_LPS25HB_Pressure_Sensor_Library
Using library SparkFun_VEML6075_Arduino_Library at version 1.1.4 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_VEML6075_Arduino_Library
Using library SparkFun_MCP9600_Thermocouple_Library at version 1.0.4 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_MCP9600_Thermocouple_Library
Using library SparkFun_SGP30_Arduino_Library at version 1.0.5 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_SGP30_Arduino_Library
Using library SparkFun_VCNL4040_Proximity_Sensor_Library at version 1.0.3 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_VCNL4040_Proximity_Sensor_Library
Using library SparkFun_MS5637_Barometric_Pressure_Library at version 1.0.1 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_MS5637_Barometric_Pressure_Library
Using library SparkFun_High_Precision_Temperature_Sensor_TMP117_Qwiic at version 1.2.4 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_High_Precision_Temperature_Sensor_TMP117_Qwiic
Using library SparkFun_u-blox_GNSS_Arduino_Library at version 2.2.0 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_u-blox_GNSS_Arduino_Library
Using library SparkFun_Qwiic_Scale_NAU7802_Arduino_Library at version 1.0.4 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_Qwiic_Scale_NAU7802_Arduino_Library
Using library SparkFun_SCD30_Arduino_Library at version 1.0.17 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_SCD30_Arduino_Library
Using library SparkFun_Qwiic_Humidity_AHT20 at version 1.0.2 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_Qwiic_Humidity_AHT20
Using library SparkFun_SHTC3_Humidity_and_Temperature_Sensor_Library at version 1.1.4 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_SHTC3_Humidity_and_Temperature_Sensor_Library
Using library SparkFun_ADS122C04_ADC_Arduino_Library at version 1.0.2 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_ADS122C04_ADC_Arduino_Library
Using library SparkFun_MicroPressure_Library at version 1.0.1 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_MicroPressure_Library
Using library SparkFun_Particle_Sensor_Panasonic_SN-GCJA5 at version 1.0.1 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_Particle_Sensor_Panasonic_SN-GCJA5
Using library SparkFun_SGP40_Arduino_Library at version 1.0.3 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_SGP40_Arduino_Library
Using library SparkFun_SDP3x_Arduino_Library at version 1.0.2 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_SDP3x_Arduino_Library
Using library BlueRobotics_MS5837 at version 1.1.1 in folder: D:\Users\Steven\Documents\Arduino\libraries\BlueRobotics_MS5837
Using library SparkFun_Qwiic_Button_and_Qwiic_Switch_Library at version 2.0.5 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_Qwiic_Button_and_Qwiic_Switch_Library
Using library SparkFun_Bio_Sensor_Hub_Library at version 1.0.5 in folder: D:\Users\Steven\Documents\Arduino\libraries\SparkFun_Bio_Sensor_Hub_Library
exit status 1
Error compiling for board RedBoard Artemis ATP.
Any suggestions please?
