Has anyone had issues with code not compiling in the arduino IDE for the artemis module specifically? Strangely, the same code compiles just fine for the RedBoard. Error readout attached. I’ve replaced the username in the filepath with ~. It seems to take issue with the SPI library.
[/In file included from /Users/~/Documents/Arduino/libraries/Adafruit_BusIO/Adafruit_BusIO_Register.h:10,
                 from /Users/~/Documents/Arduino/libraries/Adafruit_FXOS8700/Adafruit_FXOS8700.h:24,
                 from /Users/~/Documents/Arduino/libraries/Adafruit_FXOS8700/examples/sensorapi/sensorapi.ino:1:
/Users/~/Documents/Arduino/libraries/Adafruit_BusIO/Adafruit_SPIDevice.h:70:72: error: 'SPI' was not declared in this scope
                      uint8_t dataMode = SPI_MODE0, SPIClass *theSPI = &SPI);
/Users/~/Documents/Arduino/libraries/Adafruit_BusIO/Adafruit_SPIDevice.h:70:72: note: suggested alternative:
In file included from /Users/~/Documents/MATLAB/SupportPackages/R2020b/3P.instrset/arduinoide.instrset/idepkgs/packages/SparkFun/hardware/apollo3/2.2.1/cores/mbed-os/mbed.h:65,
                 from /Users/~/Documents/MATLAB/SupportPackages/R2020b/3P.instrset/arduinoide.instrset/idepkgs/packages/SparkFun/hardware/apollo3/2.2.1/cores/arduino/mbed-bridge/Arduino.h:14,
                 from /Users/~/Documents/MATLAB/SupportPackages/R2020b/3P.instrset/arduinoide.instrset/idepkgs/packages/SparkFun/hardware/apollo3/2.2.1/cores/arduino/sdk/ArduinoSDK.h:9,
                 from <command-line>:
/Users/~/Documents/MATLAB/SupportPackages/R2020b/3P.instrset/arduinoide.instrset/idepkgs/packages/SparkFun/hardware/apollo3/2.2.1/cores/mbed-os/drivers/SPI.h:98:7: note:   'mbed::SPI'
 class SPI : private NonCopyable<SPI> {
Using library Adafruit_FXOS8700 at version 2.2.0 in folder: /Users/~/Documents/Arduino/libraries/Adafruit_FXOS8700
Using library Adafruit_BusIO at version 1.10.0 in folder: /Users/~/Documents/Arduino/libraries/Adafruit_BusIO
Using library Wire at version 2.0.0 in folder: /Users/~/Documents/MATLAB/SupportPackages/R2020b/3P.instrset/arduinoide.instrset/idepkgs/packages/SparkFun/hardware/apollo3/2.2.1/libraries/Wire
Using library SPI at version 2.0.0 in folder: /Users/~/Documents/MATLAB/SupportPackages/R2020b/3P.instrset/arduinoide.instrset/idepkgs/packages/SparkFun/hardware/apollo3/2.2.1/libraries/SPI
Using library Adafruit_Unified_Sensor at version 1.1.5 in folder: /Users/~/Documents/Arduino/libraries/Adafruit_Unified_Sensor
exit status 1
Error compiling for board Artemis Module.]
Thank you!
