Artemis Nano pinout spacing? I am making a board in kicad
Artemis Nano pinout spacing? I am making a board in kicad and would like to make the socket for it.
They should fit a normal 0.1" pin spacing such as this header: https://www.sparkfun.com/products/116
Here are the dimensions - which you can also find [here
Dimensions.pdf (134 KB)
Keep in mind that the outer PTH connections are all GND. The inside connections are actual board signals. Happy tinkering!](RedBoard_Artemis_Nano/Documents/Dimensions.pdf at master · sparkfun/RedBoard_Artemis_Nano · GitHub)
