Can I update the firmware on an existing as7263 board from Sparkfun?
if this is possible can someone point me to some instructions for a way to update the firmware on an existing board?
If I could do this over the QWIIC connector even better.
Hi Mike.
Unfortunately the firmware on the AS7263 is not user programmable and can’t be programmed via Qwiic.
If you had alternate firmware for the board, you could use a [EPROM programmer to flash the EEPROM on the board, but sadly we don’t have any guides on how to do that and are unable to help with a procedure.](CH341A XTW100 24 25 Series EEPROM Flash BIOS CH341 USB Programmer Module + SOIC8 SOP8 Test Clip For EEPROM 93CXX / 25CXX / 24CXX - AliExpress 502)
