AS7265x
I am currently using a SparkFun Spectral Triad (AS7265x) connected to a RaspberryPi via I2C
Is it somehow possible to connect two of these devices to one RaspberryPi? Or is there a problem because of the I2C adress?
From the product page:
Note: The I2C address of the AS7265x is 0x49 and is hardware defined. A multiplexer/Mux is required to communicate to multiple AS7265x sensors on a single bus. If you need to use more than one AS7265x sensor consider using the Qwiic Mux Breakout.
