AS726X turning on the onboard LED
Hello!
I am unable to turn on the onboard LED of the AS726x spectral sensor. The following is the code.
#include “AS726X.h”
AS726X sensor;//Creates the sensor object
byte GAIN = 0;
byte MEASUREMENT_MODE = 0;
byte current=3;
void setIndicatorCurrent(byte current);
void enableIndicator();
void setup() {
Wire.begin();
sensor.begin(Wire, GAIN, MEASUREMENT_MODE);//Initializes the sensor with non default values
void loop() {
sensor.takeMeasurements();
if (sensor.getVersion() == SENSORTYPE_AS7262)
//Visible readings
Serial.print(" Reading: V[");
Serial.print(sensor.getCalibratedViolet(), 2);
Serial.print(“] B[”);
Serial.print(sensor.getCalibratedBlue(), 2);
Serial.print(“] G[”);
Serial.print(sensor.getCalibratedGreen(), 2);
Serial.print(“] Y[”);
Serial.print(sensor.getCalibratedYellow(), 2);
Serial.print(“] O[”);
Serial.print(sensor.getCalibratedOrange(), 2);
Serial.print(“] R[”);
Serial.print(sensor.getCalibratedRed(), 2);
else if (sensor.getVersion() == SENSORTYPE_AS7263)
//Near IR readings
Serial.print(" Reading: R[");
Serial.print(sensor.getCalibratedR(), 2);
Serial.print(“] S[”);
Serial.print(sensor.getCalibratedS(), 2);
Serial.print(“] T[”);
Serial.print(sensor.getCalibratedT(), 2);
Serial.print(“] U[”);
Serial.print(sensor.getCalibratedU(), 2);
Serial.print(“] V[”);
Serial.print(sensor.getCalibratedV(), 2);
Serial.print(“] W[”);
Serial.print(sensor.getCalibratedW(), 2);
Serial.print(“] tempF[”);
Serial.print(sensor.getTemperatureF(), 1);
Serial.print(“]”);
Serial.println();
Forgot to mention… I am using Arduino UNO and with Qwicc shield.
