AS7331 Calculation of the Result
Dear sirs.
I have a problem to Calculate UV-A UV-B and UVC.
The Register 6-10 have followed data.
REG 6=0x9C
REG7=0xCB
REG8=0x58
REG9=0x52
REG10=0x1h
IF i receiver 17,5,5 for UVA-UVB and UVC.
What are
UV-A=?
UV-B=?
UV-C=?
The calculation for TEMP is very Clear.
Tchip=Register1*0,05-66,9.
The calculation for UV is NOT clear.
I looking forward to hear from you.
Bjarne Profort
Section 6.1 Optical Characteristics of the AS7331 data sheet gives the sensitivity values for various gain settings.
Dividing the counts by the appropriate sensitivity values gives the approximate incoming intensity in uW/cm^2, per channel.
Study the data sheet and keep a copy handy, as it is by far the best resource.
As jremington said…and also if you’re after the code’s conversion, it starts on line ~274 here (and as it mentions, it refers to 7.4 equation 4 also from the datasheet)
