I have a AS7331 (Sparkfun PN:SEN-23518) I’m using the Nano IOT 33 board, have also tried UNO R4 WiFi with same results. I’m using the first example “Continuous mode example”.
The program stops at the first Initialize in the program and halts. I using the QWIC connection and have attached another device and it works fine, have also run scan I2C scan program which found the the 3 address of the 3 sensors UVA, UVB, UVC.
I’m using Arduino IDE Version 2.3.6, the laest libraries from the Sparkfun website for both the AS7331 and the Sparkfun tool kit.
Any help would be apreciated.
Thank You
Thomas Kleyn
