Assembly in C
Hello members,
I am using MSP430F1611 for my project with CrossStudio. I need to use assembly instructions in between my C code like,
void Wait(unsigned int delay)
unsigned int c;
for(c=0;c<delay;c++)
//asm(“nop”);
But above use of “asm” is giving compilation error. I am finding it bit difficult to find the proper document for this. Has anyone used this earlier with CrossStudio? A document will be much helpful.
Thanks in advance.
If you want a delay using CrossStudio, here is the function that will do that:
#include <inmsp.h>
void __delay_cycles(unsigned long n);
This “delays program execution for exactly n processor cycles. n must be a constant.”
If you still want to use the nop, then just use the function
_NOP(); // note the prepended underscore
HTH,
gm
