I suspect that the UDP interrupt hangs somewhere when I cycle the USB connection.
This is one construct that I use to set/clear bits in the CSR registers:
#define CLEAR_CSR(endpoint, flags) \
volatile unsigned int reg; \
reg = AT91C_BASE_UDP->UDP_CSR[endpoint]; \
reg |= (AT91C_UDP_RX_DATA_BK0 | AT91C_UDP_RX_DATA_BK1); \
reg &= ~(flags); \
AT91C_BASE_UDP->UDP_CSR[endpoint] = reg; \
while ( (AT91C_BASE_UDP->UDP_CSR[endpoint] & (flags)) == (flags) ) \
#define SET_CSR(endpoint, flags) \
reg = AT91C_BASE_UDP->UDP_CSR[endpoint] ; \
reg |= (flags); \
while ( (AT91C_BASE_UDP->UDP_CSR[endpoint] & (flags)) != (flags) ) \
Am I doing this right? I am afraid that I might get stuck here when pulling/reinserting the USB cable…
